Post by colcol on Oct 31, 2020 12:52:41 GMT 10
Hi looking for help to identify what year this van is please Chassis no is 66950 It is a Viscount Royal It has electric brakes Weighs 993 kg In original condition Gas fridge and stove works I also wanted to ad photos - having a bit of difficulty with this . Thanks for any help I can get . Thanks
Post by shesgotthelook on Oct 31, 2020 14:12:44 GMT 10
Post by Don Ricardo on Oct 31, 2020 17:39:32 GMT 10
Hi Colcol,
Hopefully the link Shesgotthelook has given you will assist you to post some photos of your van.
The easiest way is to use the 'Add Attachment' button if you're just wanting to put up a few one-off posts and pics. However, I notice that you are posting via your mobile, so have a look at the instructions given in the links because there is an extra step to take before the button shows on your mobile. (I've got no idea why the platform we use requires that - it's annoying!)
Just while you're posting your photos, does the serial number have a letter in front of, or after the numbers? If it does that will help us work out the date because Viscount changed their numbering system a couple of times over the years.
Post by colcol on Oct 31, 2020 18:22:23 GMT 10
Post by Don Ricardo on Oct 31, 2020 21:18:53 GMT 10
Hi Colcol,
Well done on posting the photos, including the one of the sticker with the chassis number.
Is the serial number also shown in weld on the arm of the drawbar? There should be a letter as part of it.
From what you have told us and from what I can see, I an guessing the serial number on the drawbar may be ‘R66950’. If that’s the case, then your van is a 1976 Viscount Royal. If my guess is incorrect then we will have to think a bit harder!!
Post by colcol on Oct 31, 2020 21:24:24 GMT 10
Thanks for the quick reply ! I will look tomorrow on the drawbar for the number and let you know . The picture of the chassis no I took was inside the door frame near the bottom . If it is 1976 - do you know if there is a market for them and if so what price could I get ? The van is not Registered . Thanks so much for the help so far Regards Colcol
Post by shesgotthelook on Nov 1, 2020 8:10:39 GMT 10
I think it's a bit later than 76 but I'm no expert. Have you joined the Viscount owners page on facebook? They are dynamite at establishing age of caravans. Regarding values, that's something we don't discuss on here but depending on the condition of your van, they are highly desirable & selling well at the moment, given that no one can travel overseas! Cheers, SGTL www.facebook.com/groups/ViscountCaravanOwnersAustralia
Post by Don Ricardo on Nov 1, 2020 8:50:37 GMT 10
Hi SGTL and Colcol,
You may be right about the van being a bit later, SGTL. However, I’ve checked the Viscount register and the chassis number numerals don’t match anything after 1976, hence my comment. However, I would expect there to be an ‘R’ before the number on the drawbar. If Colcol can tell us whether that’s there or not, that will help us with the date.
Colcol, the Viscount register is kept by Twocutekelpies on this forum. I’ll message her to ask her to post what she thinks.
Post by twocutekelpies on Nov 1, 2020 9:23:35 GMT 10
I'm with Don Ricardo, 1976 Royal. It's not unusual for the sticker to not have the model letter and only contain numbers. The height of the side marker lights lines up with '76, they were usually higher in the late 70s (and early 70s). Cheers Shelley
Post by Mustang on Nov 1, 2020 15:16:51 GMT 10
 This was our Vincent in original trim, it was dated Feb 1977. Sliding inside cupboard doors, some models were hinged. Cheers Brent
Post by colcol on Nov 7, 2020 8:08:17 GMT 10
Thanks Mustang for the info . Your van has rounded corner windows which mine doesn’t but when I checked inside to see if cupboards were sliding or hinged mine has a bit of both !!! Weird ! Today I will see what the drawbar numbers are and put up a post to see if we can get a better idea of what this baby is . Thanks for everyone’s support .
Post by colcol on Nov 7, 2020 10:32:47 GMT 10
I have found the chassis number on the drawbar and it does have a letter in front .... you guys know your vans !!!! It is R 66950 . It is a 16 footer and looks like it sleeps 4 . Two on the double bed and there is a fitted cushion to match the rounded bench seat at the front . However I don’t know how it fits together as we have never used the van . I will put up some pictures - any help on this would be great . Thanks
Post by Don Ricardo on Nov 7, 2020 14:03:38 GMT 10
Hi Colcol, That's excellent you've found the serial number for your van. Yes, R66950 definitely confirms that it is a 1976 Viscount Royal. It would be good to see some photos of it. There is info on how to post photos if you click here. Don Ricardo
Post by colcol on Nov 8, 2020 18:48:51 GMT 10
