Post by atlanticsteve on Oct 11, 2020 21:25:27 GMT 10
Hi, I’m trying to date the following rims off an Atlantic which I believe to be about a 1968. I was told that the caravan may have ‘new old stock’ rims from the previous year from a local car manufacturer. Any ideas? Thanks. Attachments:
Post by Rattles on Oct 12, 2020 5:59:15 GMT 10
cmtrailer.co.nz/hubs-stubs/pcd-chartsThis should help you, It is from a NZ Site, it will enable you to calculate the Rim PCD and from the 4 stud chart the common car maker using that PCD. Rattles
MRFJ55
" KEEP HOLDEN ON "
Post by MRFJ55 on Oct 12, 2020 7:41:56 GMT 10
G’DAY STEVE,
HOW YOU GOING. ? 🤙
WELCOME. 😁
I ALSO HAVE A MID 1950’s ATLANTIC CARAVAN THAT IS ONLY 9’6”” LONG WHICH SEEMS TO BE THE ONLY SIZE THEY WERE MADE.
MY VAN HAS 15” STANDARD FJ HOLDEN RIMS FITTED. THE HALF A DOZEN OR SO ATLANTIC VANS I HAVE SEEN IN THE 22 YEARS I HAVE OWNED MINE HAVE ALL HAD THE SAME RIMS FITTED.
WHEN YOU GET A CHANCE, COULD YOU PLEASE PUT UP SOME PHOTOS OF YOUR VAN.
CHEERS, MAURIE. 😎
