Post by nelliem on Aug 9, 2020 14:40:30 GMT 10
insert code here Hello, new to this so thankyou. I am assuming this is not what my roof should look like. Is there meant to be rubber or similar to stop the top from making direct contact and rubbing on the roof? I can only find one piece on a corner.
Post by Franklin1 on Aug 9, 2020 17:45:29 GMT 10
G'day nelliem, when your poptop is lowered and locked down for travelling, there should be a small gap between the poptop roof and the lower caravan roof. The poptop roof rests on the scissor lift springs when they are collapsed, and shouldn't touch the lower roof. The black line showing around the perimeter is the accumulation of dirt from the air/wind getting into the gap during travelling. Raise the poptop roof and clean that black muck off with soap and water. No rubber cushioning is required if the poptop roof is sitting correctly when lowered down.
Cheers, Al.
