Post by hsv1440 on May 18, 2019 20:17:22 GMT 10
Post by Don Ricardo on May 19, 2019 17:41:54 GMT 10
Hi Hsv1440,
Welcome to the forum. It's great to see photos of your Baravan. Congratulations.
The serial number 685 tells us that it was built in 1965, towards the beginning of the year.
If you can tell me the length of your van in feet and inches (cabin only, measured a foot above the floorline), and the bedding configuration (how many single and double beds), I can tell the model designation.
Have you see the Baravan thread in the 'Down History Lane' section of the forum? If not, go to that section, find the index thread and then click on the Baravan link. That hopefully will give you some further information about Baravan.
Post by hsv1440 on May 20, 2019 21:36:40 GMT 10
Hi Don
I think it’s around 13 foot will measure properly in the morning It was a 2 berth single beds with dinette I have emailed Bruce and he’s confirmed it’s a 1965 and will send me the rest of the production info next week I have spent today stripping the carpet and Lino out that’s been laid since underneath is a brown Lino in squares not sure if this was the original flooring but I’m assuming it is
Post by Don Ricardo on May 22, 2019 14:38:43 GMT 10
Hi Hsv1440, That size and layout means that your van is a 13' 2" 2SD I believe. Great that you've made contact with Bruce. He'll be able to give you ideas about getting the van back to original. We'd love to see photos of your work as you proceed. Don Ricardo
Post by hsv1440 on May 22, 2019 21:22:48 GMT 10
Thanks will upload some picture soon, ive stripped the flooring 1 layer carpet and 1 layer vinyl and found what I believe is the original flooring brown with a couple of black squares, ive also stripped some carpet that a previous owner has glued to the front window ledge and found the original laminate and under all the glue the pressed tin i believe will get there slowly
