Post by boofrmb on Feb 22, 2019 9:20:37 GMT 10
Hi All.
My Dad has recently passed away, and he has a 1974 (I believe) Viscount. Anyway to confirm age? It has been in a shed every since he brought it, so in excellent original condition. Will be able to get photos, all details,etc this weekend. Also it is located in Inverell, NSW
Cheers
Robert
Post by boofrmb on Feb 22, 2019 21:01:17 GMT 10
Hi All.
Got the Sn/Chassis number. It E67XX
so I now believe its a 1964 model
Post by Don Ricardo on Feb 22, 2019 22:02:55 GMT 10
Hi Boofrmb, Welcome to the forum. It’s great to hear about your dad’s Viscount. The serial number E67XX tells us quite a bit. The ‘E’ tells us that the van is an Ambassador model, and the fact that the ‘E’ precedes the numerals tells us that it was built in 1970 or earlier. From part way through 1970 the ‘E’ followed the numerals on Ambassador models. I presume that when you typed ‘67XX’, that indicates that you can see that the serial number includes four numerals, but that you can’t read the last two. Is that correct? If that’s the case then the number ‘67XX’ tells us that your van was built in 1968. Viscount introduced the Ambassador model only in 1964, but if your van was built in 1964, the serial number would start with ‘D’. The ‘E’ series serial numbers were introduced in 1965, and are sequential starting with ‘1’, so the first few hundred Ambassadors had a serial number with one, two or three digits. I hope that all helps. We can confirm the above dating of your van if you are able to show us some photos after the weekend. There are instructions on how to post photos on the forum in the ‘Forum Guidelines & Helpful Hints’ section of the forum (see the Home page). In the meantime have a look at the vans shown in this post. Your van should like one of the vans shown for 1968 or 1969. If it doesn’t then the photos will help us work out what is going on. Don Ricardo
Post by boofrmb on Feb 23, 2019 15:57:14 GMT 10
Post by Don Ricardo on Feb 23, 2019 20:24:33 GMT 10
Hi Boofrmb,
Great to see the photos of your father’s van. The style of the cladding and the colored ‘lightning bolt’ flashes on the sides of the van all confirm that it is a 1968 build, as also indicated by the serial number ‘E6780’. You may even find a more specific date (day, month and year) written in pencil under the table or in one of the cupboards if you check it out.
Are you going to keep and use the van?
Post by boofrmb on Feb 24, 2019 6:06:07 GMT 10
Hi Boofrmb, Great to see the photos of your father’s van. The style of the cladding and the colored ‘lightning bolt’ flashes on the sides of the van all confirm that it is a 1968 build, as also indicated by the serial number ‘E6780’. You may even find a more specific date (day, month and year) written in pencil under the table or in one of the cupboards if you check it out. Are you going to keep and use the van? Don Ricardo Thanks Don. Will have a look. Nah, we will be selling it, so next will be working out whats its worth, and putting it up for sale. Cheers Robert
Post by don257 on Feb 24, 2019 8:59:54 GMT 10
Do you have any inside pics please?
Post by boofrmb on Feb 24, 2019 10:41:22 GMT 10
Can get a few inside pics
Post by boofrmb on Feb 24, 2019 11:29:35 GMT 10
Post by shesgotthelook on Feb 24, 2019 18:11:43 GMT 10
Really lovely & it beautiful order! Lucky you. Enjoy!
Post by boofrmb on Feb 24, 2019 19:07:12 GMT 10
Thanks.
But as my mum really cant afford to hang on to it, it will be up for sale, so have to work how much its worth, been told around $7000 - $8000, but not sure if that's too much. Can someone give me an idea on what it maybe worth.
Cheers Robert
Post by boofrmb on Mar 2, 2019 17:32:31 GMT 10
So would anyone have a general price that I could put on the caravan?
Cheers
Post by willies on Mar 3, 2019 10:32:01 GMT 10
So would anyone have a general price that I could put on the caravan? Cheers Prices don’t generally get discussed on the forum. Do a bit of research and compare your van with others that are for sale and go from there. Good luck.
Post by boofrmb on Mar 11, 2019 6:34:58 GMT 10
Prices don’t generally get discussed on the forum. Do a bit of research and compare your van with others that are for sale and go from there. Good luck. Thanks, Very sorry, not used to selling this type of item. But my brother has placed it on Gumtree, will see how it goes. www.gumtree.com.au/s-ad/inverell/caravans/vintage-caravan/1212358637cheers Robert
Post by boofrmb on Apr 7, 2019 19:51:43 GMT 10
Post by boofrmb on Apr 7, 2019 20:00:52 GMT 10
So would anyone have a general price that I could put on the caravan? Cheers Prices don’t generally get discussed on the forum. Do a bit of research and compare your van with others that are for sale and go from there. Good luck. Thanks. I now require more info from this great group. As its a 1968 I need the follow info, or how to find out. Tare, (790kg on rego paper) GVM, not on rego paper Ball weight, again not on rego paper Thanks in advanve Robert
Post by shesgotthelook on Apr 7, 2019 21:00:20 GMT 10
Hi Robert, best way to get the weight is take it over a weighbridge!
Someone may have better advice, but I think for GVM, allow approx 300kgs over Tare for water, food, luggage etc.
Ball weight- lump of wood & set of scales.
Cheers, SGTL
Post by boofrmb on Apr 8, 2019 6:48:29 GMT 10
Thanks for the info.
Post by boofrmb on Aug 16, 2019 17:07:36 GMT 10
Hi All.
One big question on the above caravan.
I know the tyres are 13", but the rims, are they Holden or ford rims that will fit.
Thanks in advance
Robert
