tedd
Post by tedd on Apr 6, 2017 18:02:04 GMT 10
Hi All.
Need help to rego my 1969 Classic Vintage Franklin Regent. I live in ACT.
Fully Renovated 1969 Classic Vintage Franklin Regent.
FEATURES Working Original Fridge, working on gas and electricity. Working original gas stove and grill. Microwave. Reversible Air Conditioner. HD Sony Television. New Portable toilet. Sleep 4, as the table can be fold to make a double bad. Plenty of storage. 60 litre water tank.
ELECTRICAL All internal and external lights are working. Internal and external main lights are 12V and 240V. All 240V power outlets are working. All 12 volt
INTERIOR
INTERIOR FRAME New frame , with treated timber.
FLOOR New Floating board.
WALL New wall
WINDOWS All windows opens, closes and locks as normal. New Fly Screens.
CEILING Totally new ceiling build using new marine plywood and insulation.
BRAKE New master brake cylinder. New brake lines. Fresh brake fluid. Rebuild wheel brake cylinders.
FRAME Sandblasted and repainted with Silver white Knight Rustguard. New tow chain.
More photos are available on request, including photos during renovation
Just finished the renovation and its Ready for rego.
Post by Koala on Apr 6, 2017 18:44:18 GMT 10
What help do you need ?? Do you have evidence of previous registration??
Koala
tedd
Post by tedd on Apr 22, 2017 22:53:19 GMT 10
Hi Koala. Sorry just found out your reply. I am new to this forum. I need information regarding how to rego this van, in ACT. I have only the old Plate and receipt from the seller. The seller said that this van hasnt been rego for very long time. Thanks in advance. What are needed to rego?
Post by Mustang on Apr 23, 2017 8:25:55 GMT 10
Hi Koala. Sorry just found out your reply. I am new to this forum. I need information regarding how to rego this van, in ACT. I have only the old Plate and receipt from the seller. The seller said that this van hasnt been rego for very long time. Thanks in advance. What are needed to rego? Usually you will need a weighbridge tare weight ticket, gas certificate & roadworthy, they will inspect lights. Just call ACT transport department & ask what else you will need. To get to the weighbridge there is a permit of 24 hours for an unregistered vehicle.
Post by Koala on Apr 23, 2017 13:22:06 GMT 10
Hi Ted, In the ACT you will have two options. 1) If you can establish evidence of the previous registration (i.e. a copy of registration papers) then you can go to a ACT authorised inspection station which is usually your local service station and they will inspect and pass it for you. 2) If you cannot provide evidence of previous registration you will need to take what paperwork you have(receipts, copy of advertising where you bought it, photos) and do the following ; Hitch up the van and obtain weighbridge ticket. There are a number of locations Mugga Tip and some of the firewood sellers are approved. You will need to disconnect the van from the car on the weighbridge to get the correct weight. Make two bookings (can be on same day) at the new ACT Government Inspection station which is now located at Hume for a Identity Check and a Roadworthy Inspection. Make sure that you make both bookings regardless of what they tell you on the phone and you will pay a small fee on the inspection day for each. All being well you will pay a bunch of money and be on your way. You do not need gas or electrical inspection certificates. If they choose to enforce it you will need a fire extinguisher and a smoke detector in the van. You do not need a permit to move the unregistered van as long as it is being towed by a currently registered vehicle and being moved by the most direct route for the purpose of repairs and registration. Obviously life will be easier for you if the van is roadworthy with all lights and brakes working, safety chain and good tyres. The process is not as hard as it sounds but you are dealing with public servants so be prepared for anything .......stay calm.
Koala
tedd
Post by tedd on Apr 24, 2017 15:54:44 GMT 10
Hi Mustang and Koala Thanks heaps for the info. Base on those info, i think it should be fine then. Ginger cross. Thanks
