alprov
Post by alprov on Apr 17, 2017 20:31:52 GMT 10
alprov
Post by alprov on Apr 17, 2017 20:36:02 GMT 10
Researching on classic caravan site & came across a post from Boblor on bonding a floor using sikaflex 252 , brilliant product that worked well on butt joints , @ $32 a tube worth its weight in gold , many thanks to Boblor .
alprov
Post by alprov on Apr 18, 2017 14:48:51 GMT 10
With all the lower framework from the door to the rear now complete its time to tackle the top rear corner , i replaced outer skin for the moment to check for proper fit .
alprov
Post by alprov on Apr 18, 2017 16:50:37 GMT 10
Not much to go on .
alprov
Post by alprov on Apr 18, 2017 16:53:05 GMT 10
Had a look at the other side & should be able to m ake a template.
alprov
Post by alprov on Apr 19, 2017 6:10:48 GMT 10
Another photo of chassis rebuild , remember saying for a bit of fun could you do the build number in copperplate & he did this crikey .
alprov
Post by alprov on Apr 27, 2017 10:11:59 GMT 10
Recycled red mahogany @ $6
alprov
Post by alprov on Apr 27, 2017 10:19:57 GMT 10
alprov
Post by alprov on Apr 27, 2017 11:42:53 GMT 10
Rear doorside framework now complete , i had a 70x19 meranti cut in half & then planed down to size saving a $1 metre, doing it this way $42 @ 4 3.6 lengths . Mortised most timber where i could then glued / brass screwed / stapled / & fitted corner brackets in places as well as adding extra timber for strength , probably overkill but rather that than weight saving . Painted all timber with a mould / fungal primer then using left over taubmans extreme weather paint on top of that , Had to make a couple of modifications in the corner as outer skins did not fit , all good now .
alprov
Post by alprov on Apr 27, 2017 11:44:44 GMT 10
alprov
Post by alprov on Apr 27, 2017 11:48:26 GMT 10
alprov
Post by alprov on Apr 27, 2017 11:53:28 GMT 10
