Post by Roehm3108 on Jul 9, 2005 12:29:11 GMT 10
Why is it that plywood cladding of the side walls on some vans is laid horizontally, with the grain going east-west, while others have it laid vertically with the grain running north-south? Is one way better than the other, if so which? ? I intend to reclad my Chesney, for various reasons, and at the moment the plywood is fitted vertically with a wooden vertical cover strip. For appearance sake, I am considering fitting the new cladding horizontally, with a horizontal cover strip. What are your thoughts? Ray
Post by retro1 on Jul 9, 2005 19:44:18 GMT 10
Howdy Ray There is no right or wrong answer here in my opinon. As long as all the ply is going one way I think it does not matter. All the books I have go both ways? If you do not want to see the grain paint the surface with a good paint and sand between coats or do what they did in th 1960's use masinite whick has no grain. I also think that if a sheet of ply fits better one way because of cost then this to is a major way also of deciding. Hope this helps you out Cheers Retro1
