Post by galaxy65 on Jun 10, 2005 13:06:39 GMT 10
Hi Retro, Mark tells be you are the one to ask about joining. I have stripped my Don caravan down with a heat gun and I'm about to prepare it for paint. The joins at the front had canvas glued to the van. There must be a beter techneque these days ? also can you tell me what to use for filler, for the odd chip in the timber from the scapper I used to remove the paint. Regards Bret GALAXY65
Post by retro1 on Jun 10, 2005 14:42:10 GMT 10
Can you send me a picture via email please as it will help me see the join and be easier to assist you. Cheers retro1
Post by galaxy65 on Jun 10, 2005 20:00:29 GMT 10
Post by galaxy65 on Jun 10, 2005 20:01:36 GMT 10
Post by Deleted on Jun 14, 2005 17:11:18 GMT 10
paging Retro1 ......are you there?
Post by retro1 on Jun 14, 2005 20:27:41 GMT 10
Still on holidays in Queensland and have limited contact on the net. If you need to contact me please ring 0410275787 The best way I think other than the original way is to fibreglass bog it and use a product that will seal porous stuff like ply in the hardware section of your hardware joint. I used a water-proof membrane that was water based and have been in many showers now and have not had a problem. I'm not sure of the name of the product but will look it up when I get home. Cheer retro1
