neilncheryl
Post by neilncheryl on Jun 17, 2013 20:04:47 GMT 10
Been doing some repair work over the last 3 weeks Cladding all removed, found an abandoned beehive at the water filler on left hand side No framework supporting the roof on lhs (rotted away) better now More to follow as weather allows work to proceed, NeilnCheryl
Post by 56effy on Jun 17, 2013 22:28:59 GMT 10
G'day Neil, You don't muck about! Should make September no worries. Effy.
Post by cobber on Jun 18, 2013 9:52:38 GMT 10
G'day Neil'nCheryl, Not long to go till the September holidays, but it looks like you're on track You've probably noticed there's been a bit of talk as to whether Crestline vans should be called " Kings Crestline" ..... Crestline being the model. There is as yet no entry in DHL for Crestline, do you reckon there should be ? Cobber.
neilncheryl
Post by neilncheryl on Jun 18, 2013 15:41:19 GMT 10
Thanks Effy & Cobber. Not sure on How Crestline fits in but I would have assumed that Crestline was the name of the caravan and manufactured by "Kings Caravans Ltd" as per the tag. After all, Ambassador and Supreme are not manufactured by Viscount but rather are Viscount Ambassador and Viscount Supreme. Just my thoughts but could be way off track. Neil
Post by isambard on Jun 18, 2013 18:45:36 GMT 10
I recognise that driveway good to see the big beauty coming together, guys. such a striking unit, so pleased it's being given a makeover as it deserves. having seen her in the flesh I can totally understand why you travelled a few thousand kms to get her home! Izzy
neilncheryl
Post by neilncheryl on May 24, 2014 21:33:17 GMT 10
Had some hold ups but back working on the Crestline again now. A few update pics I have replaced all the front and side internal ply walls around the dining area. The frame has also been replaced. The single beds at the rear have been replaced with a double. The front corner window shelves took a lot of time making. The original ones had been replaced and the replacements were rotted and poorly fitting so I didn't have much to go on. They have turned out ok. Hopefully will be priming and undercoating this week ready to paint topcoat the week after Coolys
Post by Surf Tragic on May 24, 2014 22:26:23 GMT 10
G'day neilncheryl
That's a major job you have undertaken , it is interesting to see that timber constructed vans haven't changed much really, right up to the most modern timber framed ones. The sealants are better nowdays & keep the elements out if applied right, if only they had the sikaflex's back then that we have now .
Well, at least you have plenty of room to move around in that beauty when you're working.
Pity you have to cover all that interesting framework with ply isn't it? I think I will always leave one 1/2 finished just to look at the real work that goes into it. You should be feeling good about what you have done, it looks great.
Surf Tragic
