Post by trev and carrots on Jan 22, 2005 0:25:33 GMT 10
a friend has this sunliner and is planning a restoration. the members may be able to take a look when they do the Bridgetown run ! does anyone have an idea of what year it would be ?
Post by 52chevygirl on Jan 22, 2005 8:49:09 GMT 10
OOOOhhhhhhhh!!! Love the camoflage colour... comando style!! ;D I have just been sent some photocopies of original adds etc with dates on them... From what i can tell they started production 1958/1959 with wrap front windows (look at ours) and then went to two front windows (one fixed and one opens!!?? )from the add the one pictured looks like the add from 1964. I can email you the adds if you like.. Good to see another one- so far there is 5 in our area, 7 near Newcastle......wow and thats just the ones i've come across... Deb
Post by trev n carrots on Jan 22, 2005 14:24:00 GMT 10
yes please deb much appreciated ;D
Post by humptydumpty on Mar 7, 2005 18:55:30 GMT 10
To date the sunliner look on top of the chasis about a foot back from the coupling (sand all the paint away). It can be on either side. the number will read YYMM x number of van. Looks like my 64 Sunliner
Post by humptydumpty on Mar 12, 2005 18:50:40 GMT 10
Look hard to find a 5 in front of that 9. Then we can say for sure that it is 12/59 or...5912. I have dated 3 so far with that system. Good luck with the restoration, you have a big job ahead of you there. I am starting to sand one back now , but I am not sure what to undercoat it with as some of the Gel coat has been eroded with time. I would like to use automotive acrylic to finish it with
Post by humptydumpty on Mar 14, 2005 20:24:09 GMT 10
Dennis, So far I have only done the door, using conventional Filler/primer, spray putty and Acrylic Lacquer. The finished result was good. My main concern was for any reaction with old "substances". I am going to see what happens when I try to paint over the existing undercoat, after sanding it back. I may need a barrier coat. Oh and by the way I like it standard. It will be Off white with a Red flash and Holden 13 inch rims. The interior is good enough not to be touched, but some new Lino would help.
