Post by bobandjacqui on May 1, 2013 16:42:29 GMT 10
Here's a couple of pics of " Miss Daisy's" annexe. Original canvas awning with marconi clips. Thanks Cobber ;D Cheers Bob and Jacqui
Post by farmerbetty on Jul 25, 2013 20:51:22 GMT 10
how much does an awning like the one above cost???
Post by murray on Nov 20, 2013 7:44:15 GMT 10
Any recommendations for getting a basic awning(with some scalloping) made for a 12 1/2 foot Valiant. Send me a PM or post on forum Cheers Murray
Post by cobber on Nov 20, 2013 9:21:54 GMT 10
G'day Murray, Your profile doesn't indicate what part of this big brown land you live in so it's hard to recommend an annex maker for you but......... if you have a look at the Vintage restoration parts/suppliers thread you might find a recommended annex repairer /maker near you. If perchance you find one near you that does a good job let us know about them and I will add it to the list Cobber.
Post by shesgotthelook on Aug 5, 2014 8:38:05 GMT 10
Two options for the Phoenix. Mild weather awning Heavy duty annexe. For some reason, the door is at the back
Post by akeepsake on Aug 5, 2014 13:53:08 GMT 10
Any recommendations for getting a basic awning(with some scalloping) made for a 12 1/2 foot Valiant. Send me a PM or post on forum Cheers Murray Murray I'll give u a call about this!
Post by renee on Nov 10, 2014 9:06:41 GMT 10
Post by renee on Nov 10, 2014 9:14:12 GMT 10
FRANKLIN 1 Was mentioning that he had to consider the possability of the door scraping the roof/awning when it is touching the door. All I can add is many years ago my parents had a 72 millard that we used for all our holidays (god wish I was a kid again) and the door would also scrape the annexe roof, so the old man fitted a slallish but wide wheel that came on a bracket that the old man fitted to the top of the door on the out side, and itdid an absolutely brilliant job of solving that problem, hope it helps. Neal and Bron.
Post by Koala on Nov 10, 2014 9:32:28 GMT 10
Post by Allie on Apr 23, 2015 21:24:14 GMT 10
How do we stop water running under annexe walls and wetting floors after a downpour?
Post by Gypsy 10 on Sept 26, 2015 0:41:50 GMT 10
Both Jamo & I are going to make our own awnings but we are unsure how the canvas is stitched to the sail track ribbon. I am referring to the area in the black circle. What we need are some good close up pictures to show us how it has been done on other awnings. Any and all help is greatly appreciated.
Post by JBJ on Sept 26, 2015 9:09:09 GMT 10
Hi,
I've had sailtracks fitted to awnings that had marconi tracks, & the upholsterer used a moulded rope/plastic strip, that they sewed to the awning. I googled "sail track strip", & found a few options.
I would definitely use this strip instead of trying to sew rope in place. Its so much smoother to slide into the sail track, & I dont believe it would be hard to do.
JBJs
Post by shesgotthelook on Sept 26, 2015 9:47:10 GMT 10
We had a new awning made for Veronica Viscount, & converted all her Marconi to sail track (rope track is the correct term when buying the rail). My canvas man- made my awning, changed the van to rope track, altered the existing annexe to rope track & repaired a horse rug for $594. I think we ended up with 'Dickson' blind material which is waterproof & has been tested! Dickson has lots of suitable patterns but not many of them are available in Aus.
Post by Koala on Sept 26, 2015 10:04:02 GMT 10
Sail Track is readily available from Bunnings Item No.1109879 $16:82 for 3 metre lengths.
Koala
Post by Gypsy 10 on Sept 27, 2015 0:00:47 GMT 10
Thank you for your advice.
Post by Gypsy 10 on Sept 29, 2015 0:24:27 GMT 10
So this is a bump. Jamo & I are hoping to have these made before the nationals that's only six months away.
Post by JBJ on Sept 29, 2015 7:56:52 GMT 10
Hi Gypsy 10, I hope this is what you are looking for. I had a new sail rope section sewed into the annex of my Olympic by the local canvas guy. These are a couple of pix of how he did it. The rope actually goes thru an eyelet pressed into the canvas. I think you may have trouble getting someone to reeve the rope loop together, as I would think it could be a dying art. They actually spread the rope strands, & weave them together. I'm sure my dad, who was amonst other things, a rigger at one stage, called it "reeving" the rope. JBJ
Post by Gypsy 10 on Sept 29, 2015 18:46:31 GMT 10
JBJ wonderful many thanks. Now can I be a pain and ask for a the other side of picture 2 of your post to see the top side. As for reeving the rope it is a lost art. But... I've had a little experience with splicing ropes which looks very similar. getting that other picture of the top side may be all we need to sort out ours.
Thanks again Gypsy 10
Post by JBJ on Sept 29, 2015 20:05:25 GMT 10
Hi,
The 2 pix are both sides of the same connection.
Post by Gypsy 10 on Sept 29, 2015 21:02:09 GMT 10
Sorry my mistake. I was not looking at them close enough.
Post by shesgotthelook on Sept 30, 2015 8:56:16 GMT 10
Sorry for delay, life a bit manic atm! Give me a week for the actual annexe as I physically cannot get it out from under the bed by myself & am about to go on holidays & of course the bit I want to photograph is folded inside Anyway, here's the awning. It feels like a solid tubing & there is no rope involved at all. Very lightweight though & easy to handle. The annexe may be different.
Post by Gypsy 10 on Sept 30, 2015 9:12:23 GMT 10
Great, thanks SGTL
Post by Koala on Sept 30, 2015 17:03:57 GMT 10
Post by justanotheramy on Oct 5, 2015 11:18:55 GMT 10
I've ordered some waterproof canvas to make my little Quest an awning, but I'm wondering… Umm…
How do I decide where to attach the sail track? Along the edge of the roof? Back a bit? And how do I attach it without compromising the roof? Rivets means holes, right?
Post by cobber on Oct 29, 2015 8:55:31 GMT 10
