Post by apiarist1 on Jun 8, 2008 18:25:15 GMT 10
Tony
How is it going - any advnace on the progress towards replacement rubbers.
Regards Apiarist1
tonyh
"Dolly" 1967 Riviera
Post by tonyh on Jun 9, 2008 22:16:06 GMT 10
Hi Apiarist1 & All, There has been some problems with the plant - nothing to do with my rubber, luckily - when they are sorted out they will modify the die and do, hopefully the final sample run before the full order run. I will let everyone know as soon as that happens. Cheers, tonyh
tonyh
Post by tonyh on Jun 13, 2008 20:21:43 GMT 10
lulu
Post by lulu on Jun 14, 2008 0:54:40 GMT 10
Great News Tony..well done! Lulu
Post by humpty2 on Jun 14, 2008 19:32:07 GMT 10
Good timing Tony......I have nearly finished number 2 sunliner and the rubbers are one of the jobs to be done.
tonyh
Post by tonyh on Jun 19, 2008 17:06:09 GMT 10
News Flash Sent Lazza - Roadmaster Guru in Adelaide a sample of the rubber and it doesn't fit their Aluminum frames - Different shape altogether. Lazza is sending a sample and drawings and I will be working with him to establish whether there is enough need out there to make a new die for the rubber for these windows as well. So we need Anyone with other brands of vans built in SA pre1967 - Globe etc to let me or Lazza know to try to find out which and how many SA vans had these type of windows. Cheers, tonyh
Post by FDPUNYN on Jun 19, 2008 19:59:04 GMT 10
Hi Tony I sent you a PM in regards to the rubber.
Cheers John
tonyh
Post by tonyh on Jun 19, 2008 21:23:12 GMT 10
Hi John / FDPUNYN, You're a guest so how did you sent a PM ? Because I didn't get It. Cheers tonyh
bobt
"Ugly as Sin"
Post by bobt on Jun 19, 2008 22:53:28 GMT 10
Hey Guys, Check out the rubbers on this web site. www.uesint.com/index.php they may have a profile your looking for. (Caravan ones I mean)
tonyh
Post by tonyh on Jun 20, 2008 6:43:05 GMT 10
Hi Bobt, UES are the good people who finially pointed me in the right direction to the rubber manufactures who are making the RVR (Resto Van Rubber) I didn't see anything for the Roadmaster - how about you Lazza? Cheers tonyh
tonyh
Post by tonyh on Jun 26, 2008 20:41:33 GMT 10
NEWS FLASH * NEWS FLASH * NEWS FLASH ;D ;D I picked up the 300 meters of completed rubber today so I will be talking to the post office and letting everyone know ASAP ;D Lazza - Roadmaster master checked "my" Qualcraft window rubber and we now know that there is TWO types of Qualcraft windows with different rubbers. Lazza has contacted a rubber manufacturer near him to reproduce the "South Aussie" rubber which as described to me has a larger "T" , a back edge to clip around the window frame and a larger sealing face section. Lazza will put up a cross section and description when he can. Both Lazza's Roadmasters have this rubber and Fossie's 15' Sunliner appears to have it too. All the other Sunliner and Olympic owners that I have sent samples to have reported that my style of rubber is the one for their windows. Cheers, tonyh
tonyh
Post by tonyh on Jul 8, 2008 8:58:29 GMT 10
Hi everyone, There is still a couple of VV owners that expressed interest that I have no contact numbers for and I have sent a PM to with no response. If you don't need it now, that's OK - just let me know as I have had a very good response and don't want you to miss out on this first run if you need still need it. ;D Cheers, tonyh
Post by ralphy on Jul 8, 2008 17:40:48 GMT 10
Hi TonyH, we will certainly need rubbers for our 61 sunny so if you still have some i would need enough for the four side windows and one pushout at the front, the rear window has been swapped out for a modern windout at some stage, ( still unsure if this is a bad thing or not ) does the rubber go around the whole frame or just sides and bottom maybe Sutcac can clue me in ?? anyhow just registering serious intrest. cheers Ralphy
tonyh
Post by tonyh on Jul 8, 2008 18:26:59 GMT 10
Hi Ralphy, On these type of Qualcraft window the rubber is only on the sides and bottom. The top of the frame is the hinge and is screwed and sealed against the body. ;D PM me with your details and I will send you a sample so you can make sure it is the correct one for your model ;D Cheers, tonyh
Post by humpty2 on Jul 26, 2008 18:01:49 GMT 10
tonyh
Post by tonyh on Aug 19, 2008 19:34:54 GMT 10
Thanks Humpty 2, ;D I wish giving up work was an option - maybe in about 8 years - earlier if Gold Lotto works out Cheers, tonyh
tonyh
Post by tonyh on Aug 30, 2008 19:08:49 GMT 10
Hi All, To everyone that was worried about missing out on getting rubber - Good News - I got onto a new manufacturer (Thanks Lazza) and sent them my die and ordered another 400 metres and I received it the other day - excellent service and product. ;D So if you need some PM or E mail me. Cheers, tonyh
tonyh
Post by tonyh on Oct 7, 2008 21:19:36 GMT 10
To all you owners of Beautifull Sunliners when you are at your get together please pass on the good news to anyone who hasn't heard that I have remanfactured the rubber for their Qualcraft type windows - available now. ;D Have a great time ;D Cheers, tonyh
Post by humpty2 on Oct 8, 2008 18:33:36 GMT 10
Tony, I will be sending you a PM in the next couple of days for more rubber. Regards Peter.
Hillbilly
"Fun in the Sun ..."
Post by Hillbilly on Oct 11, 2008 4:26:38 GMT 10
Hi TonyH
Will also pm or ring you shortly re getting a set of window rubbers for my 59 Sunny.........
Cheers, Hillbilly ;D
Post by Dean Webb on Oct 13, 2008 20:42:01 GMT 10
Hi Mate, We have an old sunliner with bubble front and rear windows which are cracked and crazed and leaking!!. We have completed the inside and are about to update the outside. We heard there is somewhere that makes reproduction windows. Can you provide any help or advice on how to replace windows?? Thanks Deano
miaow
Post by miaow on Oct 18, 2008 20:32:01 GMT 10
I know these rubbers are for the littler windows - we're after rubber for them, but REALLY need the rubber for the front and back - our Sunliner is (I think) from 1962 and the windows are wraparound. Anyone have any pointers? We're in Melbourne. Beth
tonyh
Post by tonyh on Oct 19, 2008 18:05:22 GMT 10
Hi Deano & Beth, The man you need to contact is Spyder - a fellow member and all round good guy - he has the contacts for the rap around windows and the tricks on fitting ;D Cheers tonyh
tonyh
Post by tonyh on Jan 5, 2009 6:31:10 GMT 10
Hi All, ;D Just a bump as I have been getting a few e mails etc as to whether I still have some rubber left - Yep - have plenty ;D Cheers tonyh
Post by boblor on Jan 18, 2009 11:14:04 GMT 10
Hi tonyh and VVers Restoration of Olympic Riviera chassis no. 35 -- Just commented work on this project and one of the first jobs was to polish the window frames (manufactured by L O Baker Brisbane) and fit new rubber seals delivered by tonyh, -- Fitted perfectly, just like new again. The van is a 1965 model. Though this might help other Olympic owner with early vans up to chassis no. about 1450 with large single pane type windows fitted. Cheers boblor
