Post by cruisindoug on May 12, 2011 12:01:34 GMT 10
A little hard to read if anyone would like a better resolution copy sent via email just PM me. Cheers Doug
Post by Rattles on May 12, 2011 18:00:27 GMT 10
Copy and paste the link use the free download button or PM me with your E-Mail address and I will send you a copy this is for a mid 60s fridge from a Viscount Ambassador 15' Caravan rapidshare.com/files/458576674/Morphy-Richards_Astral.pdfLink Dead see below p.s. Section 9 of the user manual has service information
Post by Geoff & Jude on Apr 18, 2012 17:35:39 GMT 10
hi all we've stumbled on a set of original operating instructions for a morphy-richards astral gas only fridge. they're the same as the instructions already posted on this thread, but may be a little easier to read. hope they help someone. geoff 'n jude
Post by Rattles on Apr 18, 2012 18:36:05 GMT 10
From above: Morphy-Richards Astral Fridge B230 User Manual Covers Models P150 and A160 also. I have a higher Resolution copy if it is needed PM me with E-Mail and I will send to who ever requires same. Rattles Attachment DeletedRe-upped link working 2/8/2014
Post by nitesurfer on May 8, 2012 23:41:11 GMT 10
Thanks guys for this very handy information.... At least I have a clue now how to operate the fridge.... As my fridge is old I have one question... Do we just try it on 240V and then see if the thing doesnt blow up we try gas??? I know about gas lines etc being cracked etc... but what about the ammonia or whatever inside the fridge? I was thinking of checking frige works whilst it is out of van when i do the reno.... My sister told me something about just turning the fridge upside down for a few minutes then righting it and then lighting it.... her ex was a fridgey so maybe there is something to it.... Anyone heard of this???
neal
Post by neal on Feb 8, 2013 21:01:14 GMT 10
Just had an old guy out to do a gas cert , and a couple of changes to our old van, and he said if it does not cool properly, as it has not been used for many years, to take it out and carefully rotate the fridge a couple of times then sit for a couple of hours, apparently the coolant "settles" Neal
Post by cruisindoug on Jul 30, 2013 15:28:55 GMT 10
Just wondering if anyone is currently using this style of fridge? I am considering dusting off the old fridge and checking out if it still works - or if it is feasible to get it working ... I was wondering if anyone has been through the process of checking out an old gas fridge that hasn't been used for some time? If so, best way to do so? Plans for bench testing at this stage are: 1. Pull off panels and check for cleanliness, signs of leakage, damage or other issues. 2. Check data plate for correct inlet pressure. 3. Obtain and fit up (or get fitted up temporarily) appropriate regulator, and gas cock. 4. Run and see if it gets cold! 5. If it doesn't get cold, try the upside down trick and try again. Stumbled across this link to Servel (Electrolux-Servel) fridges in my travels ... Cheers Doug
Post by akeepsake on Jul 30, 2013 17:02:41 GMT 10
My morphy gas / electric had been sitting round in the van and unused since the 70s! It didn't work when I switched it on so I checked the connections for voltage and checked the electric element wasn't open circuited , checked the thermostat was working ok ( I'm a sparky) but if your not sure about your thermostat just short it out to test if its getting cold. It still didnt work so I rolled,it around upside down a couple of times and that sorted it! Hope that helps Cheers Andrew ;D
Post by cruisindoug on Aug 1, 2013 9:53:05 GMT 10
Thanks Andrew, my fridge is gas only, so not sure how the thermostat works on it yet, I am guessing some sort of bimetal strip that operates to control the gas flow to the burner???
Hopefully I will be into it tomorrow, time permitting!
Cheers
Doug
Post by Rattles on Aug 9, 2013 8:24:04 GMT 10
The Low res file for Morphy Richards Astral Fridge C200D Attachment Deleted. As before If anyone requires a High Resolution copy PM and I will send via E-Mail. Rattles
Post by cruisindoug on Oct 4, 2013 7:49:15 GMT 10
Turned the fridge upside down for a couple of days, grabbed some new line and fittings and cracked the gas a little; and its leaking from the burner / shut off valve .... My understanding is that this valve should not open until you apply heat to the tube hanging out the side of it, as its designed to shut off if the flame goes out ( ) So .... anyone have a dead fridge that they might like to give up this part from to make another one live??? Its marked Teddington, Type TZ, made in England. Cheers Doug
Post by Koala on Oct 4, 2013 8:45:49 GMT 10
Try sending an enquiry to Hotfrost in the UK.
info@hotfrost.co.uk
Koala
Post by Rattles on Aug 2, 2014 18:08:55 GMT 10
The User Manual for Morphy Richards Astral Fridge C200J .
Cannot Upload due to insufficient space ??
Rattles
Post by humpty2 on Aug 2, 2014 19:14:05 GMT 10
Have you got anything on the A160D Rattles....its in a 1961 van?
Post by Rattles on Aug 2, 2014 21:11:24 GMT 10
No only the three models above Send me a PM and with your E-Mail and I will sent all three one may be close.
Rattles
Post by trousersnakepliskin on Oct 15, 2016 22:32:21 GMT 10
Post by trousersnakepliskin on Oct 15, 2016 22:52:09 GMT 10
I bought a van made in 1974. It has a M-R Astral fridge which "keeps things cold but the freezer doesn't freeze anything," according to it's last owner. I need to make sure it works properly on gas because out where I go there's no power apart from my generator. Before I touch it I need to see some kind of operators manual. There's no model number but it differs to the one on YouTube in that the freezer box is in the top left corner, one rack mid-way down, another beneath it, then at the bottom two ignition buttons on the left, a source knob next on the right, then a thermostat knob. Off to the right is a viewing hole for the gas. It has a picture of a flame next to it so I assume this is where one lights it. It has no lighting hole on the right but has a teardop-shaped metal flap on the back which obvious opens up the flame part, but cannot be accessed in service. Does anyone out there know what model this is apart from it's approximate year of manufacture, and can I get instructions for it? If not, are the instructions for older models applicable to burner servicing and so on?
kcair
Post by kcair on Jun 18, 2018 14:43:20 GMT 10
Yes, thank you and can you email me a copy of this manual? I just got a 1964 Shasta and it has the Morphy Richards frig.
I do appreciate your help.
KC 714-293-5866
Post by jsullybun on Jul 24, 2019 9:20:52 GMT 10
From above: Morphy-Richards Astral Fridge B230 User Manual Covers Models P150 and A160 also. I have a higher Resolution copy if it is needed PM me with E-Mail and I will send to who ever requires same. Rattles View AttachmentRe-upped link working 2/8/2014
