Post by Deleted on Feb 3, 2012 19:31:29 GMT 10
Post by 1954homemade on Feb 3, 2012 19:39:42 GMT 10
Hi John, Looks like you are cracking on with Doug's car - he will be happy. Such a shame for you Doug that the end of January has come and gone and so now you are on the new pricing scheme ;D ;D ;D ;D ;D Luv Di
Post by cruisindoug on Feb 5, 2012 22:33:35 GMT 10
Sounds good John didn't see the post till just then, this place is so busy if you don't check it for a day you miss stuff! I'll be over there to drop off the rest of the bits and pieces tomorrow. ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D Di, the ute made it into the shop before the end of January
Post by cruisindoug on Feb 6, 2012 17:48:58 GMT 10
Jellybean
Post by Jellybean on Feb 6, 2012 19:04:43 GMT 10
Underside is all sprayed with stoneguard now. Will get some thick gloss black over that tomorrow. Then we can get it right way up again and start on the 1/4 panels and custom roll pan . Didn't plan on doing any work on the floor but this is typical of an old car once you strip it right back. There are always unexpected surprises. . It's only money Doug. he he.
Post by cruisindoug on Feb 6, 2012 20:28:27 GMT 10
Yep I was a bit surprised that it had the rust in the floor and the other spots - the only place it was visible was the sill. Reckon the timing was definately right to get this done before it got too bad and cost even more
Jellybean
Post by Jellybean on Feb 7, 2012 19:19:05 GMT 10
Underside all glossy black now. Panelwork finished on one door , other door nearly done. Will tip body back over when the underside has dried.
Post by cruisindoug on Feb 7, 2012 19:48:47 GMT 10
;D ;D ;D ;D ;D ;D
Better get my finger out and get some of the other stuff done I wanted to do!
Jellybean
Post by Jellybean on Feb 8, 2012 20:39:57 GMT 10
Right rear 1/4 panel has ugly patches cut out and new sections welded in . Firewall being smoothed up now. Bonnet started on.
Answer your phone Doug ! I need to know if you want the passenger door lock hole welded up. ( Central locking maybe ) Cheers John
Post by cruisindoug on Feb 8, 2012 20:47:23 GMT 10
Sorry John was at work all day today was going to give you a ring tomorrow, re the lock ..... yep weld it up please! I will figure a way of rigging an alternative way in if the locks / alarm fails Sounds like I'm missing all the fun while I'm at work! I'll drop in Friday if I get a chance and take some piccies... Cheers Doug.
Post by humpyboy on Feb 8, 2012 20:53:33 GMT 10
Sounds like I'm missing all the fun while I'm at work! I'll drop in Friday if I get a chance and take some piccies... Cheers Doug. Doug, we're all missing the fun while we're stuck at work mate, roll on retirement, I can handle being old but this work capper is a pain in the you know where.
Post by humpty2 on Feb 9, 2012 19:18:16 GMT 10
Post by humpyboy on Feb 9, 2012 19:56:43 GMT 10
Humpyboy.....what makes you think you will have time to sit in front of the computer when you retire Its 7 days a week, with no days off Please allow me to elaborate, when I mentioned "this work capper" I meant for some other clown ie "The boss" I look forward to the day I wake up and go to the shed to do my own work for me and not others I don't even care if it takes all day and night so long as I don't have a nappy following me all day long.
Post by smiles on Feb 10, 2012 11:12:23 GMT 10
John does a brilliant job so should look great when it's done Doug, you've sure put the hard yards in on this.
Post by cruisindoug on Feb 10, 2012 20:44:15 GMT 10
Post by cruisindoug on Feb 13, 2012 6:28:50 GMT 10
Heading into a new week and its time to pull the motor down to check it out, just wondering if anyone can recommend a place in Brisbane to do the cylinder head ... going to unleaded valves. It looks like the head has had some work so I need someone that knows their way around modded red motor heads ...
Jellybean
Post by Jellybean on Feb 13, 2012 6:49:25 GMT 10
Hey Doug. Browns Engineering just round the corner from work. He does all TPCs work (who built my motor) . They both do Robbie Browns real quick 202 drag car. It is the " Greens Nice "FJ Holden.
Post by cruisindoug on Feb 13, 2012 18:48:43 GMT 10
Thanks John spoke with them today, sounds like the go! ;D ;D Greens Nice certainly sounds the goods, and goes hard too! Will be aiming to pull the motor down tonight / tomorrow night and drop it in on Wednesday. Spoke with Rares today he is not sure if the tailgate skin will be in by then though ... I guess you have a few other things to be going on with!
Jellybean
Post by Jellybean on Feb 14, 2012 19:33:02 GMT 10
We now have 2k primer on the r/h 1/4 panel and doors. The body is flipped over to the other side and welding finished on the l/h 1/4. Roof is nearly done. We should have the whole cab in primer by the end of the week.
Post by cruisindoug on Feb 14, 2012 20:16:11 GMT 10
Sounds good John, started pulling the engine down this arvo .... From this: to this: Will drop in for a sticky beak tomorrow. ;D ;D ;D Cheers Doug
Post by cruisindoug on Feb 15, 2012 18:47:02 GMT 10
Couple more progress pics: Couple of mint looking doors! RHS rear quarter is looking very nice too ... Doug
Jellybean
Post by Jellybean on Feb 23, 2012 19:24:45 GMT 10
We now have the L/R 1/4 panel and roof in 2k primer and the custom rear roll pan with rego plate recess is welded on. The guards and bonnet are all under way. Once they are done we have to trial fit all the panels and get all the gaps nice. Very time consuming but we are getting there slowly. Cheers John
Post by cruisindoug on Feb 23, 2012 20:08:06 GMT 10
Sounds like a couple of big days on the ute, getting there, can't wait to see it all back together again!
matt41
Kennedy's Rule
Post by matt41 on Feb 26, 2012 19:22:54 GMT 10
That's going to be one awsome ute Doug. And John you da Man cheers Matty
Post by cruisindoug on Feb 29, 2012 20:06:17 GMT 10
