Post by cmcz on Aug 9, 2007 17:11:54 GMT 10
Post by cmcz on Aug 9, 2007 18:20:33 GMT 10
Sorry that took so long, it was my first try
Thanks Cheryl
Post by tinnie on Aug 9, 2007 21:36:12 GMT 10
Welcome aboard CMCZ! Millard built vans from late 50s/early sixties, however that Millard sticker looks like it came of a late 70s Millard. Siler aluminium and windows, door handles etc indicate mid to late sixties. Brand is hard to guess possibly a Viscount? maybe Murrumba star? Is there a chassis number on the aframe? Doh! Miss read your post chassis - SL301....can't help with decifering that. Cheers and happy V-Ving! Gristy
Post by Deleted on Aug 9, 2007 22:39:14 GMT 10
I believe it to be a Viscount Valiant ....................
Post by cmcz on Aug 10, 2007 10:04:17 GMT 10
Thanks Gristy Did think it may have been a Viscount Valiant but was not sure, don't know much about old (or new) caravans The rego sticker lists it as a 1988 Millard, someone was having a go there I knew by the shape that it was not 1988 but more like the earlier 70"s. She is cute and light, the main reason for the purchase. Do you know of any publications re Viscount Valiants Thanks for taking the time to reply Cheers Cheryl
Post by cmcz on Aug 10, 2007 10:06:28 GMT 10
Thanks Mark T any ideas re the numbers on the tow bar SL301 Cheers Cheryl
Post by cmcz on Aug 10, 2007 10:07:54 GMT 10
Woops sorry Draw Bar Thanks Cheryl
Post by Daggsey on Aug 10, 2007 10:19:29 GMT 10
Hi cmcz,
As an owner of a 1968 Viscount Valiant, I'm not to sure that what you have is one of these. It appears to be too short and doesn't have a middle window over the sink. Viscount may have made a smaller version ("Viscount Cadet" ;D..sorry all you Don fans, just joking) and maybe someone out there could enlighten us further.
The outside cladding with pressed horizontal lines would indicate to me a 70's van, although I find the patterned ceiling to be interesting.
As far as removing the paint, unfortunately it is paint stripper and good old elbow grease that is required ;D.
daggsey
Post by cmcz on Aug 10, 2007 10:56:28 GMT 10
Thanks Daggesy Never heard of a Cadet, will try to find out more about them. The van is 11ft. I 2 found the ceiling interesting and at first thought it was pressed metal but on closer inspection it appears to be some sort of bernie board, you know the stuff compressed dark brown stuff (very technical description ) Cheers Cheryl
Post by Daggsey on Aug 10, 2007 11:09:25 GMT 10
Hi Cheryl, I didn't mean to mis-lead you with the "Viscount Cadet"....it was very much said with tongue in cheek . daggsey
Post by cmcz on Aug 10, 2007 11:36:19 GMT 10
LOLOL
Thanks Daggesy
You can see how green I am
Cheers Cheryl
Post by Daggsey on Aug 10, 2007 11:52:21 GMT 10
Hi Cheryl,
Glad no offense was taken ;D
I'm still no clearer as to the type of van you have, but maybe someone will come up with an answer for you.
The nearest I have seen to yours in shape is an Aristocrat which I think were manufactured in Perth. The ceiling is the interesting part, unless of course it was added later.
daggsey
Post by Deleted on Aug 10, 2007 17:02:33 GMT 10
Post by humpty2 on Aug 10, 2007 20:13:39 GMT 10
I wrecked a 16 foot van recently ....the roof material, windows, laminex and the cupboard latches were the same........aluminium panelling was the same too!! I was told it was an early sixties van and it too was registered as a Viscount, but the only signage was "Sapphire" Sydney. It was too far gone to be saved.....you went outside when it rained to keep dry "
Post by Franklin1 on Aug 10, 2007 22:14:34 GMT 10
Hi Cheryl, if you are reasonably computer savvy, have a go at researching newpaper archives. Click on this link to a previous thread... vintagecaravans.proboards30.com/index.cgi?board=technicalstuffboard&action=display&thread=1178950812There is a heap of information available about Viscount caravans. You get thumbnail pictures from your search enquiries, and you have to pay if you want to download readable sizes. To show you an example of what you can see with an initial search, here is a thumbnail picture from March 1968 (enlarged low resolution)... I will delete this picture in 24 hours because I am contravening the newspaper website copyright rules. cheers, Al.
Post by tinnie on Aug 10, 2007 23:20:19 GMT 10
Don't wanna start a 'knowledge war' but have definately seen that profile Ally on silver alumium vans of late 1960s. The "angled" window frames also typical of some mid-late 1960s vans. The pressed metal looking ceiling is unusual. It would be pressed masonite and usually seen on early sixties vans Possible explanation - the sides are not original??? I believe that mark T is on the right track about the Viscount bit. Mark - I am a bit worried about that 'Windsor" in the background of the pics ;D Cheers, Gristy
Post by cmcz on Aug 11, 2007 1:27:05 GMT 10
Thanks Mark T
I can see where you are coming from, there are obvious differences. Will keep looking to try to solve the problem
Cheers Cheryl
Post by cmcz on Aug 11, 2007 1:29:50 GMT 10
Hi Al
Thanks for that. I have been looking on the www but so far no luck. Off to your link now
Cheers Cheryl
Post by cmcz on Aug 11, 2007 1:33:34 GMT 10
Hi Gristy
You could be right as the van is listed as 1988 on the rego papers lolol someone was having a go there..... So it could have be "done up" and sold off to someone as a much newer van than it really is. Although I found it obvious that it was not 1988 and was probably early 70"s
Cheers Cheryl
Post by Deleted on Aug 11, 2007 17:49:19 GMT 10
Quote Cheryl " Thanks Mark T
I can see where you are coming from, there are obvious differences. "Sorry Cheryl, I really must do somethin' bout this drinking problem .....it looked the same to me when I posted the pics but you're right ....there ARE obvious differences I just had a yarn to the owners of the Viscount Val ....they showed me the rego papers, and its a 1970 model (god forbid ....I stuck photos of it on this forum ) and the rego papers say its a VISCOUNT. Yours is obviously older judging by the ali pattern design, so whatever yours is, its gotta be late 60's. As for the Viscount Val I photographed, its a real cute lil van, and I would've bought it, except that the bastards that run this website won't allow post 1970 vans ;D ;D Funny thing .....the owner of the Viscount Val told me there's some sort of "old caravan" movement happening, and that there are people "getting off on them" .......silly people ;D ;D ;D Mark
Post by boblor on Aug 11, 2007 22:03:31 GMT 10
hi Cheryl The rear split windows were not availiable until early '68, but the c'board door handles are those used in mid'60's' , spashback laminate used in '60's and '70's (Olympics). Cheers boblor
Post by cmcz on Aug 14, 2007 12:06:57 GMT 10
Hi Mark Thanks for the reply. I am really pleased with my purchase even if it is a bit of a mish mash. There has obviously been quite a bit of work done on the van over the years in bits and pieces. Tom is hard at work and had almost finished the internal repairs (rot in back corner) with a repaint to follow. Thennnnnnnnnn it is my turn with new seating and curtains, lots of sewing. Have to decide on a colour scheme. I did want to keep it as original as possible, any suggestions. Cheers Cheryl
Post by cmcz on Aug 14, 2007 12:16:02 GMT 10
Hi Bob That clarifies a bit for me. The back window has been replaced with a solid pane but the front seems to be the original and is one large opening pane. I wonder if there was a typo at the RTA, seems odd that the rego papers say 1988 and the split windows come in 1968. The table leg is one that I have not seen before and is in the shape of a "D" that sits on the floor with a long piece of tubing going up to support the table, held to the floor with a wing nut. Is Olympic a brand of caravan or a model? Any idea on colour schemes of the time Bob Many thanks for the reply Cheers Cheryl
Post by boblor on Aug 14, 2007 22:38:50 GMT 10
Hi Cheryl Olympic is a fibreglass van manufactured in Q'ld from mid '60's until the late '80's. The bodies are fully moulded for models called Riviera , Contessa, 16' models, Debonair 14' model, Micro Styleleader 11'6" and 19', Stardust avail.19'and 21' models. Another model called Travel Trailer not fully moulded avail. 18' to 30'. Great vans Cheers boblor
Post by tinnie on Aug 14, 2007 23:04:59 GMT 10
Hi Cheryl, Table leg design sounds the same as the one in my Franklin (1963 I think) and also the one in my old Roma (mid 60s), It was common in the early-mid 1960s. Cheers, Gristy
