fozy
Post by fozy on Oct 28, 2019 16:27:06 GMT 10
I need to cut new guards for my 50s bondwood have purchased thin stainless sheet what is the neatest easiest way to cut the sheet?
Post by Franklin1 on Oct 28, 2019 20:09:03 GMT 10
G'day foxy, What is the actual thickness of the stainless sheet? I have cut 1mm stainless using an angle grinder with the thin 1mm blades. Didn't take long for the small cuts I made. Cut edges were fairly smooth, but needed a final cleanup with a fine file. A nibbler as used on corrugated roofing sheets is an alternative, depending on the thickness of your stainless sheet.
Cheers, Al.
Post by markclap on Nov 12, 2019 20:16:04 GMT 10
agree with Al regards 1mm blade on an angle grinder. It's a great way to go on straight or very gentle curved cuts.
For tighter curved shapes a nibbler can be fine but if you can access a plasma cutter then make a wooden template and just follow that with the tip. It's great for most metals. Seen it used for 2mm aluminium and other materials much thicker, very effectively.
