fozy
Post by fozy on Sept 16, 2019 17:16:24 GMT 10
Hi i have removed all the J rail from my 50s bondy& plan to replace it once the van is painted my question is how do I cleanup the rail no slicone so thats good but dont want too bright & shiny Cheers deb
Post by Franklin1 on Sept 16, 2019 22:08:43 GMT 10
G'day deb,
Are you asking how to clean the underside of the J-rail so you can reseal it back on the van when that time comes?
Or, are you asking how to clean the top side that will be on show when the van is finished?? I presume when you say "but dont want too bright & shiny" that you mean the top side. If so, clean lightly with a pad of soapy steel wool dipped in warm water. The more you rub with the steel wool, the shinier the aluminium will get, so stop when you are happy with the appearance.
