Post by surferboy1958 on May 11, 2019 18:15:41 GMT 10
Window came apart while removing old window rubbers. Any ideas on how to remove & repair ?
Post by Koala on May 11, 2019 19:10:30 GMT 10
Your windows seem to be similar to most other aluminium windows. to remove them you will need to clean out whatever is in the ends of the top hinge and then slide the complete window out sideways (leaving the top half of the hinge attached to the van) You should then find a screw holding each corner together. In your case a screw is either broken or missing.
Koala
Post by surferboy1958 on May 19, 2019 20:24:54 GMT 10
