Post by surferboy1958 on May 11, 2019 17:53:19 GMT 10
G'day everyone It's been a while since i last used the Baravan (2011 ?!!!). So i thought i should sell it and use the proceeds to do up the old Convair. Started tidying up the van to sell it. A bit of fresh paint & new window rubbers & tyres WAS the idea 🙄 BUT... you paint one bit.. and the next bit looks tired..so you paint that bit.. and the next bit and the next etccetcetc Then you start stripping out whats left of the old window/body seals to fit new ones..... And... The window comes apart !
Post by surferboy1958 on May 11, 2019 18:05:29 GMT 10
I was trying to remove the old perished rubber out of the groove. The rest of the seal perished years ago and i had some horrible stick on foam stuff to seal between the window & body. Need to figure out the correct way to remove Baravan window and how to fix it. Seems each caravan is slightly different. Looks like a rusty screw has snapped. May as well look at replacing all the buggered hinges and locks
