Post by aussieute on Jan 1, 2019 18:32:47 GMT 10
I need some power points single or double and light switches small size also single fluro light old square kind cheers chris
Post by kerri on Jan 5, 2019 6:35:08 GMT 10
Mmorning. Not sure where you live but there is a place in Fyshwick. I got mine there. Wanted them to look old.
Page 6 of my thread has a couple of pics. I used old powerpoints for visual, above kitchen but new ones for the fridge and charging etc. They all work.
Kerri
Post by Roehm3108 on Jan 5, 2019 7:44:42 GMT 10
Check with any electrical store that deals with Clipsal. I know the light switches are available and would think the power points still are too. Probably a special order.
Post by aussieute on Jan 5, 2019 8:07:07 GMT 10
Thanks didn't know they still make them was going to use new ones where not seen but might be able to replace them all cheers Chris
Post by thegeneral on Jan 5, 2019 12:48:21 GMT 10
I just for interest googled "vintage light switches" there are a lot of suppliers there, Graeme
Post by aussieute on Jan 5, 2019 14:24:13 GMT 10
Every time I have looked for suppliers they don't have the same style as in the van thanks chris
Post by Warrenk on Jan 5, 2019 18:21:37 GMT 10
Been there, done that. I have checked every possible place that sells power points and sadly the only ones are available are pretty modern looking in bright white or black. If you are restoring an old house there are electrical components available, but not for caravans. If you do get some second hand ones make sure the contacts feel tight when you push a plug into it. If they are a bit sloppy the power point might end up like the one you have in the picture.
Warren
Post by aussieute on Jan 5, 2019 19:58:00 GMT 10
Thanks warrenk most are going to be put in the van as to give original look will be using 12 volt mostly that one is the only original one left been through a lot of building wreckers with no luck but one of the forum members has some and i will get checked out before fitting cheers chris
Post by kerri on Jan 6, 2019 10:13:07 GMT 10
I can go to Fyshwick and have a look for you. I need to go there next week. PM your mobile and I will take pics for you. Kerri
