Post by Warrenk on Nov 19, 2018 17:57:23 GMT 10
My recently purchased Roadhaven came with weight distribution hitch draw bar brackets and springs, but the mounting part on the towbar tongue was not available. I have attached a photo of the parts I have. If anyone has a similar setup would you be able to take some photos and post them here please. I would like to fabricate one so I can use the setup on the caravan. Thanks Warren
Post by Wodnas on Nov 19, 2018 18:50:16 GMT 10
Post by hughdeany on Nov 19, 2018 19:12:19 GMT 10
Hi Warren,that’s an Evans Bros level ride towbar setup,around in the sixties,if you google you will see the car setup and maybe make it yourself. This was the forerunner to the Hayman Reese weight distribution hitch. Hope this helps, Cheers hughdeany
Post by Warrenk on Nov 20, 2018 22:28:51 GMT 10
Maybe the Evans Bros WDH or the correct name being E.B.LEV.L.RIDE Towbar Unit might be a bit more than just an attachment to the tongue. From the pictures on the brochure it looks more like the towbar is part of the unit. Could explain why the towbar tongue part of setup wasn't there with the rest of it. It was part of the towbar attached to the vehicle. evans bros1 by evans bros2 by Warren
