Post by mel on Sept 11, 2018 9:32:59 GMT 10
I am after some ideas for hardware I could use to pin the two parts of my barn door together. I was going to use a barrel bolt but discovered that it won't work. I have a groove at the bottom of the upper door, so I can't get the two parts of the barrel bolt close enough together. The door didn't originally have anything holding the two parts together. It has a cabin hook on the upper door to hold it open but not on the lower door. On a windy day the lower door swings closed.
Post by Roehm3108 on Sept 11, 2018 10:42:37 GMT 10
Hi Mel Can you build and attach an upper and lower wooden backplate to which you can then fit the barrel bolt? Or perhaps a bolt with a longer shaft? Or a garden gate type of barrel bolt?
Post by mel on Sept 12, 2018 9:19:27 GMT 10
Yes, I did consider the back plate and longer bolt. I would prefer not to have to resort to the back plate and haven't found a barrel bolt that is long enough.
Post by Rattles on Sept 12, 2018 9:42:22 GMT 10
Post by Roehm3108 on Sept 12, 2018 15:30:09 GMT 10
If all else fails mel, a 3 inch skewed nail will hold anything!!!
Post by mel on Sept 13, 2018 11:00:49 GMT 10
Rattles you are an ideas man! I hadn't thought of doing that.
