Post by franivy on Sept 9, 2018 19:51:10 GMT 10
Has anyone replaced the water tank in a Sunliner? Any information appreciated.
Post by Mustang on Sept 10, 2018 18:38:30 GMT 10
Has anyone replaced the water tank in a Sunliner? Any information appreciated. Hi , Like any water tank replacement you need to jack it into place, use metal straps (can be rubber reinforced) to anchor to the floor. As near the axle as possible, some use a metal stone deflector in front if you are likely to be off road. When hooking up your pipe to the sink use a one way valve & preferably have a hoop under the sink to keep the system primed. Cheers Brent
