Post by france on Jul 7, 2017 7:43:40 GMT 10
Hi, Can someone help me with the Year of An aluminium viscount ambassador with these numbers welded on the A frame ( S278E or 5278E ) Please thank you ...
Post by Franklin1 on Jul 7, 2017 12:44:56 GMT 10
G'day france, and welcome to the forum! Your chassis number will more likely start with the number 5, rather than the letter S. The Ambassador model had chassis numbers starting with the letter 'E' in the late 1960s, up to around 1970, and then Viscount changed the numbering system and started counting from 1 again, with the letter E switched to the end of the numbers. Based on your number, you would most likely be looking at having a 1971 or 1972 model. We have a sister forum for caravans built from Jan 1970 to Dec 1979, so you might like to join up over there and get heaps more useful info relating to your van. Click here: Classic Caravans forum (As far as I know, you can register to join the other forum using the same 'username' that you've used here, if you wish) cheers, Al.
