Post by greenisgo on Dec 21, 2015 7:41:26 GMT 10
Does anyone know the procedure for using this fridge on gas? The information on the lowest level of the fridge suggests that onle changing the gas/electric setting is necessary. But doesn't the gas need to be lit? If so, where...?
Post by Rattles on Dec 21, 2015 8:48:27 GMT 10
Which model Hallstrom Fridge if is either Hallstrom HJ2 or HJ3 Fridge, I have the user manual in PDF format PM me with your E-Mail and I will send a copy to you.
Rattles
Post by Koala on Dec 21, 2015 12:27:47 GMT 10
Turn the control from Electric to Gas. Turn the gas control knob to the maximum. Down low on the right is a small brass button, hold this button in while you also hold a long match to the tube that runs to the rear of the fridge. Now this is the frightening bit, that tube has a row of holes from which the gas will light and follow along the tube and up the back to light the burner. You must continue to hold the little brass button until the burner is well lit which can be observed through a little mirror . This little mirror is placed at the rear under the burner but will likely need a clean as it will be very dirty. Remember that you are dealing with gas so be careful. It is guaranteed to put the wind up you when you first light that tube and see flames disappear up the back of the fridge. I would recommend removing the fridge and cleaning any rubbish before you start. Koala
Post by greenisgo on Dec 30, 2015 7:10:55 GMT 10
Thanks rattles for your offer of a pdf of the Hallstrom guide. But what is "PM". I never did shorthand...
Thanks also to the next responder who gave a good account of the procedure for lighting the gas - I can't remember your name. The process sounds unnerving! How would i get the fridge out of it's very tight space to clean the mirror?
Post by Rattles on Dec 30, 2015 10:53:11 GMT 10
greeisgo - Sorry about the Short Hand, Click on the posters Name (blue text) on the top L/H corner of post then Select "Send Message" Type and send Message.
See the Message I sent you at top Tool Bar of all pages.
Depending on you Van access to clean the mirror is usually via the lower vent on the outside wall.
Rattles
PS. if you go into your user Profile and in the "Signature" Field insert your general Location, and any other relevant info (see at the bottom of my post) this will enable a member close the give you help.
Post by shesgotthelook on Dec 30, 2015 12:37:56 GMT 10
PM- Personal message
trina
Post by trina on Sept 2, 2016 9:20:36 GMT 10
Which model Hallstrom Fridge if is either Hallstrom HJ2 or HJ3 Fridge, I have the user manual in PDF format PM me with your E-Mail and I will send a copy to you. Rattles
trina
Post by trina on Sept 2, 2016 9:23:38 GMT 10
Rattles.... i have the same issue and would appreciate a copy of your user manual also please cruiser444@hotmail.com
Post by lindaj on Aug 12, 2020 15:11:22 GMT 10
Post by lindaj on Aug 12, 2020 15:14:07 GMT 10
I have a manual but your explanation is heaps more explicit, any warning on trying it on one that hasn't ran on donkeys, that brass button doesn't move.
Post by Koala on Aug 12, 2020 18:53:46 GMT 10
I have a manual but your explanation is heaps more explicit, any warning on trying it on one that hasn't ran on donkeys, that brass button doesn't move. The fridges seem to accumulate rubbish like paper, leaves, spder webs etc so i recommend removing the fridge to give it a clean before attempting to light it. While you are in there maybe use some compressed air to clean the burner. Koala
