Post by 2sneezles on Nov 23, 2015 19:19:53 GMT 10
hello has anyone got a window for our old caravan 76 x 54 cm aluminium with rounded corners at bottom push out type also any window fittings please thanks all
Post by overlanda on Nov 23, 2015 20:30:28 GMT 10
Are you after the early type with the rubber that seals on the body or the later type with the inner and outer frame as i could have some of them in one of the parts vans that are laying about. Regards Gerald
Post by Rodnet on Nov 23, 2015 22:08:23 GMT 10
Email sent to you Gerald Cheers Rod
case
Post by case on Nov 26, 2015 16:08:57 GMT 10
Hi , I have a window available , opening in caravan-wall 770 wide and 610 high Case.
case
Post by case on Nov 27, 2015 16:12:48 GMT 10
Further to my reply yesterday this window can be cut down in height from 61cm to your required size of 54cm, not in width the opening needs to be 77 cm wide. Where are you? Case.
Post by 2sneezles on Nov 27, 2015 20:46:05 GMT 10
hi my window is 76 wide and 54 high thanks
Post by 2sneezles on Dec 10, 2015 13:17:16 GMT 10
Hi case, Sorry I forgot to answer your post. I re mesured my window and it is 770 wide so your window would fit perfectly if I cut the height down. My parents are in Melbourne on Saturday, would you like to sell your window? I could get them to pick it up from you!
case
Post by case on Dec 10, 2015 19:11:51 GMT 10
Hi Louise,ashame you did not answer earlier, I have just sold it. I may have a solution though. I have another frame same size but no sash for it. I have an idea of making a sash for it out of a larger sash I have but I need to discuss this with a friend. If you can let me know the opening measurements in your van, I will let you know if it is a goer. By the way these windows do not have the seal against the van but have a frame that is screwed to the body of the van using a sealant. The frame has a fixed seal that the sash closes against (seal is available) and the sash has a glass seal( called a wedge) Also Available.Regards Case
