Post by eddieegg on Aug 26, 2015 17:28:33 GMT 10
Hi there My wife and I are rebuilding our 1958 Sunliner and need to replace the old rusted 13 inch Holden rims. Can anyone tell me what size wheel and tyre will fit inside the wheel arch. It totally open as we are also replacing the axel and hubs.
Cheers Daz
Post by telemike on Aug 26, 2015 19:33:57 GMT 10
155r13 will fit. 165r13 will probably fit. I think 14s normally rub at the top under suspension compression, at least they did on my coilover sprung 1960 Sunliner.
thomas
Post by thomas on Oct 15, 2015 19:38:49 GMT 10
Hey eddieegg,
Suggest if you're replacing axles & hubs, you go a 9 inch hub of whatever stopping method you choose, with the ford 5 x 114 pcd stud pattern. Your options for wheel sizes will then be pretty much endless.!
My thoughts only...of course! I say this as my Viscount has the early holden stud pattern (5×108) and i was very limited to wheel variations and sizes.
Rgds,
T.
