Post by mibosa on Jun 6, 2015 9:44:42 GMT 10
Could someone please advise me of the advantages and disadvantages of replacing a cracked glass window with perspex?
Regards,
Bob
Post by gregh on Jun 6, 2015 13:58:17 GMT 10
If the glass is fitted correctly and the rubbers are in good condition, you shouldn't have any issues other than they are more susceptible to breakage from rocks and accidental flexing or body flex. You can use window cleaner's and detergents to clean them and they provide a clearer view.
The benefits of Perspex are it takes a heck of a lot to break; stones and rock usually bounce off. Perspex will also flex much more freely and generally wont crack. Disadvantages for Perspex are it is not as clear - good enough to see through but not as clear as glass. You shouldn't use window cleaners or detergent on Perspex as it can and will cloud the view; water and a soft cloth is about it for cleaning otherwise you get fine scratching.
I have used the 3mm Perspex available at Bunnings to replace smaller windows; mainly because it allows me to do it myself - I wouldn't try to trim glass to size.
Cheers Greg
Post by DC3Td on Jun 6, 2015 18:52:08 GMT 10
Gday Bob. "Observatory" has recently fitted Lexan windows to his current renovation.Perhaps have a look at his method & finished task.
You can see his build (Restoration - 60s Ambassador .... > in General. Bottom of his Page 7 begins his window installation process)
Post by mibosa on Jun 6, 2015 19:08:03 GMT 10
Thank you Greg and DC3Td for your responses. I am watching Observatory closely as we have similar vans, albeit mine having a aluminium frame.
Regards, Bob
