Post by Koala on Jun 13, 2016 18:39:17 GMT 10
Hi Chris, not sure why you would want to replace your old roof, it is a beauty with lots of life left in it You are doing a great job and I look forward to seeing the end result. Koala
Post by aussieute on Jun 13, 2016 20:18:10 GMT 10
Hi Vans looking good. Can I ask what did you use to seal the edges together? I tried builders bog as recommended it but didn't work, notice some people have aluminium strips down the side but I didn't want to make holes. Have used a metal filler it is a base and hardener like body filler i will find out name tomorrow it is made for filling large dents as it won't crack like body filler hope this helps cheers chris
Post by aussieute on Jun 13, 2016 20:21:39 GMT 10
Hi Chris, not sure why you would want to replace your old roof, it is a beauty with lots of life left in it You are doing a great job and I look forward to seeing the end result. Koala Most of the timber is rotted with water and age on the sides so i am trying to use as templates to rebuild it the same as it was once cheers chris
Post by aussieute on Jun 26, 2016 17:13:00 GMT 10
Post by Jennison on Jun 26, 2016 22:58:23 GMT 10
It's looking great Chris, I will sent you a photo of the roll top door handle on mine Jenno
Post by aussieute on Jan 1, 2017 13:43:30 GMT 10
images uploadtried to post photos of progress so far and mucked up hope haven't posted twice slow going as doing a lot of the small jobs and trying to find the parts I am missing cheers chris
Post by Roybeth on Jan 14, 2017 21:11:39 GMT 10
Hi Vans looking good. Can I ask what did you use to seal the edges together? I tried builders bog as recommended it but didn't work, notice some people have aluminium strips down the side but I didn't want to make holes. Have used a metal filler it is a base and hardener like body filler i will find out name tomorrow it is made for filling large dents as it won't crack like body filler hope this helps cheers chris Interested to learn what was the filler that you used, have read a bit about a lot of fillers don't have any flex and end up failing, so interested about a more flexible one Helen
