simmo
Post by simmo on Nov 30, 2014 14:15:09 GMT 10
Post by DC3Td on Nov 30, 2014 15:44:40 GMT 10
Gday Simmo & welcome.First off its probably better you post this in Members Photo section.Anyhows to your aquisition,click onto our Down History Lane then Caravan Index which if you`re right will be Valiant.There you can check out ones whose profile (shape) could be same/similar to yours.You give a drawbar number which you can kinda place between numbers alreay mentioned there to give you a more precise age.Re the profile you might check for types of side striping/flashes,actual shape of front/rear bulkheads (rooftop curves),internal layout/configuration.Pen/pencil scribbles in/under/behind doors/cupboards/bedding etc.Lots of builders used to write their name/innitials & date in these places.This`ll give you something to do while waiting to u/load pics & answers from others. (Admin might move these two posts there)
