Post by heywok on Nov 3, 2014 15:38:17 GMT 10
Hi all i am trying to replace the fridge in a Sunliner Gracemur and it is slightly higher than the bottom of the timber cupboard the cut out for the fridge is cut to the bottom of the hinges of the cupboard above is there a trick to removing the fridge with out making the cut out bigger? any ideas or assistance greatly accepted?
Post by Rattles on Nov 3, 2014 16:12:35 GMT 10
Give Make, Model of Fridge and also some Pictures and you will have a better chance of some help. Most of the older models bolt through the floor and later models through the front edges of the fridge. I would be surprised if the fridge was built in a manner that it cannot be removed without demolishing part of the cabinetry.
Rattles
