Post by dizdeb on Sept 28, 2014 10:41:09 GMT 10
We have just purchased a 1968 Quest van from South Australia and for Qld rego they need an ATM. How is this calculated? It has to be related to springs, brakes etc not just your loaded weight plus a bit. Can't find anything on Qld t/port web sites. Can anybody help us with this? The van stare is just under 1000kg and has hydraulic brakes. Thanks Darryl & Deb.
Post by suzanna on Sept 30, 2014 20:23:49 GMT 10
hi, there is info on main roads site ... pig trailer or self assestment...you may have to check van weight on weigh bridge $15 located at scrap metal merchants or local dump which will issue you with ticket/ then plus 100 kg for clothing food etc.... if van is still registered in s.a i would cancel or let it run out... then re register on a self assesment form which can be obtained from main roads....fill out as new registration or you will need a road worthy for the brakes.smoke detector.fire extingisher..gas certicate if applicable and inspection at main rds,,, believe me it is easier to self assess... had a van that had been registered as an olympic a long time ago and thought i would do the right thing and change it to sunliner... but all i did was open a can of worms,,, hope this is of sum help,,,, go vv
