Post by gregh on Sept 16, 2014 16:51:13 GMT 10
I'm going to attempt to salvage and reuse the laminex off the table and the slide lid over the stove - on both, the chipboard is deteriorating. I was planning on using a heat gun and a scraper to soften the glue and lift the laminex. Has anyone had any experience doing this or is there a better way?? Both these are installed in a 71 Olympic Debonair if makes any difference. Thanks Greg
Post by Rattles on Sept 16, 2014 17:21:15 GMT 10
I have Removed Laminex from particle board by soaking in water, The sand the back to smooth the glue.
Rattles
Post by shesgotthelook on Sept 16, 2014 17:22:11 GMT 10
2up
Post by 2up on Sept 16, 2014 17:29:57 GMT 10
I'm not claiming this to be my idea, but it really does the job very quickly. Get a can of spray gun cleaner from an auto store, loosen the edge of the laminate, tip a little gun wash in and keep going. Please use safety equipment, but it makes the job fast and easy!
Post by Observatory on Sept 16, 2014 18:41:02 GMT 10
I seen laminex literally peel itself off chipboard from being left out in the rain for a few days.
Post by atouchofglass on Sept 16, 2014 21:07:10 GMT 10
In the dim recesses of my mind I do remember a fellow on here a few years ago that did up laminex table tops. He also used the water method of removing the laminate.
Atog
Post by gregh on Sept 17, 2014 18:12:15 GMT 10
Thanks Guys, I'll put it out in the weather because it's sure to rain between now and the weekend. If it doesn't, I'll use the glue remover/cleaner! Cheers. Greg
Post by Rattles on Sept 17, 2014 19:25:51 GMT 10
Tip - Pour Hot water to speed up the expansion of the particle board.
Rattles
