Post by christopherb on Sept 10, 2014 17:26:27 GMT 10
thanks for a great site .i have a viscount ambassador aluminium caravan with chassis no E889 single axle 18 ft and I'm wanting to re rego. it has been unregistered for 30 yrs, vic roads needs the gross trailer mass . I'm unable to find any old rego stickers or any other relevant paperwork,so i hope someone will be able to help me.
Post by Don Ricardo on Sept 10, 2014 23:02:57 GMT 10
G'day Christopherb, There's some information on Viscount Ambassador's in the 'Down History Lane' section - you can find the Ambassador thread by clicking here. Maybe you've already found that? I'm not sure if you know the build date of your van, but if you compare the serial number and the design of your van (including the flash on the side which is often the most accurate guide to age) it will give you an idea of when it was built. Based on the serial number by itself I would guess 1967 or 1968. For what it's worth, the advertised weight of the 18ft 6 in Ambassador in both 1967 and 1969 was 19.5 cwt or about 990 kgs. As I understand it, that's the tare weight of your van, ie unladen weight. To get the gross trailer weight, you'll probably need to hitch up the van and take it to a weighbridge. Don Ricardo
