Post by iloverust on Aug 7, 2014 20:14:26 GMT 10
Hi I'm new to the van resto game so any help or advice your willing to part with is much appreciated I'm after a few things initially 1. The existing bushes on the spring shock units are perished and need replacing does any one have a contact or idea were I can get replacement shock / spring units? 2. As the van is a gracemur it's has the corner non transparent Perspex windows, I want to replace these with a clear type window, I'm after a place that either supplies the window or a material. Also after the rubbers required. 3. The existing rims are a lite rusty and have a few bad spots which look to far gone. Are the rims a Holden stud pattern? We're can I source new rims? 4.what type of brake pads do the vans use? And we're can I find replacements I'd appreciate any help on the above or any other points you may think could be valuable Nick
Aussie
Post by Aussie on Oct 27, 2014 19:50:46 GMT 10
Hi I'm new to the van resto game so any help or advice your willing to part with is much appreciated I'm after a few things initially 1. The existing bushes on the spring shock units are perished and need replacing does any one have a contact or idea were I can get replacement shock / spring units? 2. As the van is a gracemur it's has the corner non transparent Perspex windows, I want to replace these with a clear type window, I'm after a place that either supplies the window or a material. Also after the rubbers required. 3. The existing rims are a lite rusty and have a few bad spots which look to far gone. Are the rims a Holden stud pattern? We're can I source new rims? 4.what type of brake pads do the vans use? And we're can I find replacements I'd appreciate any help on the above or any other points you may think could be valuable Nick Hey iloverust, just wondering if you have had any luck with your above questions? #1 - Do you have any pics of these? #2 - Cant help here, sorry. #3 - Have you measured the PCD of the rim? Having this measurement + google should be able to help determine the rim. #4 - Taking these to a brake specialist will help identify them. Worst case scenario, they can re bond them. Hope this helps
Post by telemike on Nov 13, 2014 17:22:25 GMT 10
Quite some time ago, JBJ posted the below info. I have tried to google the parts, with no real success in finding the bushes, though I might do better if I pulled a unit off and had a better look at it. I did establish that in "* 2 x UL36F606A SUZUKI SIERRA 4-96-12-98SPD", the 4-96-12-98 measn April 96-December 98 when Suzuki Sierras were the same (ie a manufacturing run). I, too need to redo the bushes, so let us know what you end up using.
"I rebuilt a Sunliner independent suspension model a few years back. At the time Spyder gave me a list of Suspension bits needed, from King Springs. I managed to fix mine without buying any of these bits.
I've just found the document . I sent it to Roger in WA when his fell apart on a kerb, & I think it got him sorted out with the repair. For what its worth, here is the list.
PARTS AS FITTED TO SPYDERS SUNLINER SUSPENSION ( HOPEFULLY CORRECT)
* 2 x Sleeves FH105 Sleeve THR-M55X2-48 I.D. X 120 LONG
* 2 x Seats FH2015 Seat 60 I.D. SPRING LOW – FH1015-20
* 2 xLock Rings M55x2 OFOR FH1015-2
* 1 x KPF – 215 350-65-12.5-13-30016 PROSPORT
* FRONT SHOCKS SUZUKI VITARA FITTED KING COIL OVER SPRINGS KONI HEIGHT ADJUSTABLE
The above is how I wrote down what he gave me over the phone. I have no idea if I made any errors transposing the numbers, as I haven’t had to check any of it
I make no apologies if its not correct, but I think it was OK back in 2008."
