Post by Franklin1 on Aug 4, 2014 21:27:32 GMT 10
Post by Sam D on Jul 19, 2015 23:25:00 GMT 10
Hi there, I am looking for information re. the provenance of our recent purchase. It is definitely a Millard and probably a Safari and has the chassis number M8858. Any info greatly appreciated. Cheers Sam
Post by Blue Bull on Jan 30, 2017 10:32:46 GMT 10
What type of timber should I be buying to repair/replace rotten wall pillars and underfloor support members??
Rob NZ.
Post by blue bull on Mar 14, 2017 19:00:03 GMT 10
Hi Did you ever find out what timber to use to replace the rotten timber cheers gerry
Post by tomqvaxy on Aug 30, 2019 21:51:40 GMT 10
a recent reading suggested "Tasmanian Mountain Ash - well seasoned" if that's any help.
Post by walkad on Feb 26, 2022 18:18:09 GMT 10
I have a 1996 van - Luxuryline Micro - with a rusty chassis that needs sandblasting and rustproofing. I am concerned that the plywood floor may be damaged by the sandblasting. Anyone with experience of similar process? As the rust is not flaking, would rust converter and epoxy paint be an alternative?
Post by aussieute on Feb 27, 2022 9:45:54 GMT 10
A wire brush and rust converter would be the way to go as have to get van high enough to get under to sand blast some use fork lifts to lift it up to work under wouldn't want to use fork on my van for possible damage take your time and do it yourself cheers Chris
Post by walkad on Mar 1, 2022 6:46:51 GMT 10
Thanks Chris. Yes rustconverter seems best option. If only thd rain would stop and the humidity drop for better painting. Do you have successful treatment suggestions? Havd you tried PBS? Adrian
