Post by DC3Td on Jul 6, 2014 19:24:02 GMT 10
Post by Deleted on Jul 7, 2014 6:53:26 GMT 10
Hi Gordo.. The problem with those lights is .... they have the lamp holders protruding out the back .... No good for surface mounting on a caravan. Right style lenses Wrong backing plates. Reddo
Post by sportsman 1 on Jul 7, 2014 14:57:08 GMT 10
They are the ones I fitted to the Clipper.
No problem on that, the originals were the same and cant see them from inside because of the inner lining.
Leigh.
Post by DC3Td on Jul 7, 2014 17:46:34 GMT 10
Gday Reddo & Leigh.Slot head screwed to a nice piece of timber backing with holes drilled out to accomodate lamp holders should take care of business. gordo
Post by Deleted on Jul 7, 2014 19:39:59 GMT 10
Gday Reddo & Leigh.Slot head screwed to a nice piece of timber backing with holes drilled out to accomodate lamp holders should take care of business. gordo Yeah ... Thought about doing that when I was tidying up the lights on the front of the supalite.. but the "cavity " between inner and outer skins is only 25mm thick and I didn't want the rear end of the lights and wiring jutting into a block of timber on the inside of the van. They must have been available with sideways mounted lamp holders at some stage. Reddo
Post by DC3Td on Jul 7, 2014 20:33:05 GMT 10
Yo Reddo.Actually the backing timber would be affixed to the back of light,then screwed to the outer wall of said `van.All that would be showing internally would be the wiring.Alternatively & this is w/o looking at any,(cos mine havent arrived yet to go on a landy tub trailer)perhaps the lamp holder could be removed & turned sideways with a saddle clamp holding it in place? gordo
