Post by stephen&Julie on Jun 12, 2014 15:12:34 GMT 10
Hi All As some of you know I work away a lot and I’m off again this time down to central coast NSW so I’ve bought myself another home away from home a 20’ Viscount Ambassador circa 1966 I reckon, hopefully Al will help out here, anyways she in good nick and will make a comfy home for the next 24 months Cheers Stephen&Julie
Post by stephen&Julie on Jun 14, 2014 17:15:18 GMT 10
Hi All, had a spare double window so today out with the old air con that doesn’t work and in with the old window, much better Cheers Stephen&Julie
Post by DC3Td on Jun 14, 2014 17:43:43 GMT 10
I see Tinkerbell worked her magic.Guess she`ll wave her wand again & get you a matched pair of tail lights too. Good score.
Post by boblor on Jun 15, 2014 10:34:28 GMT 10
Gee I am glad I am still on the road from Broken Hill, otherwise I would had had another job on my plate. Cheers boblor
Post by stephen&Julie on Jun 24, 2014 18:09:56 GMT 10
Hello All Just finished repainting the stripes on the Ambassador, changed them from green to black, looking a lot better now Cheers S&J
Post by 1954homemade on Jun 24, 2014 22:39:03 GMT 10
Hi Steven & Julie,
Good pick up Steve. I know you mentioned at Cooly Rocks that you were looking for another van.
Looks like you are already stuck into it and bringing it up to your normal great standard.
All the best Di & Paul
Post by kharde on Jun 28, 2014 16:20:20 GMT 10
Your van looks almost the same as mine (currently doing mine up [78 model though ]). I'm curious to see what you think (actually alittle concerned) - do you think the dual axle vans can take more weight than the single axle? (Reason I ask - I've already installed all the mod-cons in my van) I) Flush toilet ii) Reverse cycle Air-conditioner iii) Water pump 12V (marine battery coming).
I tried to compensate the extra weight to a degree by removing all gas/ water tank (now removeable)... but guessing I'm going to add an extra 100kg (conservative estimate).
Anyway - your van looks like a beauty - I'm jealous. I wish I saw yours back when I bought mine - I have spent SO MUCH TIME sandblasting rust, rust proofing, rebuilding hatches, wedging stuck windows open/ etc..
Post by stephen&Julie on Sept 20, 2014 15:56:02 GMT 10
Hi All, All set up in Kempsey for work. Cheers Stephen&Julie
